A3 8p brake conversion
Wanting to do a brake conversion on my 1.8 tfsi before adding any more power to it.
i no the s3 brakes fit straight on but does anyone else have any Recommendations for me to look at before spending a fortune on s3 brakes.
aiming for the car to be able 230 bhp 300nm, so I want something powerful enough to stop.
thanks in advance.
I'm specifically looking to have the caliper look of an S3 or RS3 and paint them green and have the Audi logo on the caliper, I need to know if there is a conversion kit or if I could buy the correct size disc and if so what size, what type or size of caliper will fit my car and will fit the ferodo ds2500 pad as everyone recommending the ferodo pads and what combo and sizes I need to achieve this look / combo.
Cheers Ads
This is an example of a big brake kit:
https://www.killerbrakes.com/product/audi-rsq3-big-brake-upgrade-brembo-8pot-calipers-365mm-wave-brake-discs-new/
S3 brakes bolt straight on as long as you get all the bits. Here's the full list:
You can install the S3 brakes on your car but you have to get all the parts, not just disks and pads. You need the calipers, the carriers and a few other bits.
Front, if you want to do it properly:
LH CALIPER 1K0615123K
RH CALIPER 1K0615124K
CARRIER 1K0615125G qty 2
RETAINING SPRING 4F0615269 qty 2
PAD SET 1K0698151B
BRAKE DISC (345x30mm) 1K0615301M qty 2
LH SHIELD 1K0615311C
RH SHIELD 1K0615312C
FLEXI HOSE 1K0611701N qty 2
BOLT N10647602 qty 4
SCREW N90948802 qty 4
SCREW N91073301 qty 6
BRACKET 1K0611841A
BRACKET 1K0611842A
SCREW N90718601 qty 2
PIPE 1K0611763A
PIPE 1K0611764A
CLIP 191611715 qty 2
And for the rear:
1K0 615 423 G caliper left BLUE POWDER COAT FINISH
1K0 615 424 G caliper right BLUE POWDER COAT FINISH
1k0 615 425 T carrier left BLUE POWDER COAT FINISH
1k0 615 426 H carrier right BLUE POWDER COAT FINISH
1K0 615 601 N rotor (2x)
5N0 615 611 E dust shield left WILL NOT FIT w/o serious modifications
5N0 615 612 E dust shield right WILL NOT FIT w/o serious modifications
1K0 698 451 K pads
N 910 815 01 bolts (4x) â rear (carrier to hub) 14mm triple square
cheers
