Disable TMPS
Hello is it possible to disable TMPS light/ Text written in dash cluster(tyre pressure system fault)? This is for a A6 C7 2012. On older models you can change the coding and remove the fuse, is that still the same case with this audi model. I believe this one uses the tmps from rotation of wheels but not sure.
yes it can be done with VCDS coding for sure, ive disabled the system myself. If you want to "hide" a fault i couldn't say with certainty but i would say it would be the same
Thanks for the reply. do you have a similar model to mine? would you know which channels to change. I am using obd11. is it take out the fuse then change the figures from coding?
thanks
