Audi A6 Wiring diagram
Hello does anyone have an Audi A6 C7 S line 2012 wiring diagram. Having some issues with modules and it would really help. Thanks
there are many, any particular ones you are looking for?
Hi thanks for the reply. I have the lights on for TMPS, traction control, ABS so something related to those.
thats a huge volume of diagrams im afraid id need something a little more specific
Hello Asad,
ABS and Traction Control warnings are usually associated with either the ABS sensors, or the signal from the hub itself. Not sure why you are associating the issue with wiring faults before eliminating -at least - the simple sensors.
47 minutes ago, Magnet said:
Hello Asad,
Hi do you think he needs it plugged in as both the faults mentioned rear there ugly heads when the battery is failing as the main ECU goes into a default strategy to try and save the electric as both units consume a lot of power when operating.
