thnujan Posted June 3, 2022 Share Posted June 3, 2022 The car revs but struggles when in drive or reverse but doesn’t go anywhere. there was a loud knock and then the warning light came on. RAC came and they saw some filter has the seal not put properly and oil was leaking out. Could this be gearbox oil? 63k miles Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted June 3, 2022 Share Posted June 3, 2022 4 hours ago, thnujan said: The car revs but struggles when in drive or reverse but doesn’t go anywhere. there was a loud knock and then the warning light came on. RAC came and they saw some filter has the seal not put properly and oil was leaking out. Could this be gearbox oil? 63k miles Hi it could well be gear oil as the box is struggling to maintain enough pressure to drive the car. Steve. Quote Link to comment Share on other sites More sharing options...
thnujan Posted June 3, 2022 Author Share Posted June 3, 2022 1 hour ago, Stevey Y said: Hi it could well be gear oil as the box is struggling to maintain enough pressure to drive the car. Steve. What could have been the bang sound then ? Quote Link to comment Share on other sites More sharing options...
thnujan Posted June 3, 2022 Author Share Posted June 3, 2022 (edited) 1 hour ago, Stevey Y said: Hi it could well be gear oil as the box is struggling to maintain enough pressure to drive the car. Steve. Here is the report Edited June 3, 2022 by thnujan Personal detail Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted June 4, 2022 Share Posted June 4, 2022 15 hours ago, thnujan said: Here is the report Hi basically its telling you that the pressure switch is reducing the gearbox function due to lack of oil pressure therefore its put itself in to a protection strategy so the gearbox won't self destruct due to the leak, the drivers mirror adjustment fault could be down to corrosion in a connector block but I would definitely get the gearbox leak sorted first, as for the bang I have no idea. It would have been wiser to post the codes and reports first as they are real time info and not a description from a personal perspective of what happened, it cuts out the guess work. Steve. Quote Link to comment Share on other sites More sharing options...
