Rear Axle Beam mount/carrier replacement
Hi folks, just wondering the easiest way to replace this bush on an A4 B8 Quattro TDI.Will the rear diff need to come off or is there away to raise the diff enough to insert bush. My current bush has split at the top.
thanks I’m advance,Jim
Hi, thanks so much for reply, Ill just be replacing this one. It bolts to the underneath of rear diff. Have you any experience of replacing this particular bush?
Thanks, Jim
😀 I may have launched mine too hard
  • 1 year later...
Hi Jim.
Just reviving this post to see how you went about replacing the bush. Mine has done the exact same so need to replace.
