Q7 Front lower suspension arm
Lower front suspension  arm Bush is worn,  con I replace the bush.
Hello Bob,
I guess you can just replace the bush, but why just the bush, rather than the less-work -more-comprehensive method of renewing the complete arm?
Try pricing a Lemforder arm.
Power flex sell the bushes separately but if your replacing either the arm or the bush and doing it yourself it’s worth getting a replacement bolt that goes through the rear bush as the bush sleeve and bolt corrode together resulting in the bolt not sliding out and needing heating or cutting out. The bolt has an elongated washer on it that adjusts for wheel alignment so needs marking up with tipex or similar otherwise it won’t drive properly after refitting.
Thanks for the info guys  but I've  recently been told that you can't  replace the Bush. At a quandary  now as what to do.
