ABS light won’t clear
Steering angle sensor i recalibrated it but I get this in image I attached can anyone please help?CBDED225-FA7D-4727-8079-30E8FA4C3396.thumb.jpeg.907e8ffab7bb21bf976e1edc8b5b2d01.jpeg
Hi sorry but why did you recalibrate the sensor was it replaced?
I changed my battery then abs light came on with fault 00778 steering angle sensor fault so recalibrated it but fault would not clear
Silly suggestion, but did you drive it after battery change as this normally clears it.
Thanks for reply yes I’ve been driving it since and hasn’t cleared!! I’m unsure from the picture it says main controller 819.09deg and sub controller 818.78 is the sensor broke?
  • 1 year later...
Yes you need to charge it or do the reset in the eeprom
