MMI issues
Conorc1983
Good afternoon all! I’m wondering can i ask your advice. I bought an a6 c6 3.0 TDI Quattro for a bargain. The only fly in the ointment is that the radio, screen and button are all completely dead. I’ve checked some fuses (but not entirely sure which ones to check - I’ve checked a 30a fuse in the boot and replaced just in case it was bad.)
when I took out the left hand boot liner I saw this
which I see is the amp and the other parts I’m not sure.
When I disassembled this, I was greeted with this
so I’m wondering if anyone can advise on what else I should check. And also if these other random boxes are actually needed.
I also got a vcds scan done which I’ll attach too!
Any help would be greatly appreciated!
Log-TESTA6POST-WAUZZZ4F86N138801-380650km-236524mi.txt
Another quick update folks. I was in the engine bay doing some servicing last night when I noticed the plenum drain completely blocked and a pool of water sat there stagnant. After I cleared that and cleared the drain, I thought some of the water may have seeped through the firewall to the components.
when I removed the MMI / CD player in the glove box, the 10amp fuse in the back of the unit looked rusted. So I replaced it and plugged it back in and SUCCESS!!!! Everything powered back on!! So I’ve basically left a heater in there today to try and dry parts out. While it wasn’t saturated, it was a little damp.
hopefully this helps someone!
