Radio Code or Not..?
Hi There,
I've just bought a new xtron radio but before I change it could I check whether there is a radio code required from the original radio.? I know on my Skoda providing I fit the radio that came with the car there isn't.???
If there is code can I get this from VCDS before I swap it out.?.?
Thankyou
2 hours ago, Mario T said:
Hi There,
Thankyou
Hi if its an aftermarket radio I don't think coding will be required as it works independently of the original system and has no affiliation with the BCM and probably has a can bus shunt in it  so any cars system will accept it, but the code for the original will be on VCDS so just make a copy of it as plan B.
  • 4 weeks later...
Thanks Steve is it easy to get the code form VCDS.?
