Drl problem and need some advice.
Hi all, on my a7 I've had a fault that's happened twice now. Got in the car and started it and comes up with the warning n/s side light out. If I turn the ignition off and let the car power down then turn it back on the drl comes back on. When it is out the indicator and main light works fine. Like I said it's happened twice now. Just hope it's not the headlight as I see there pricey second hand 😭 any help would be greatful thanks.
Thanks steve. I think I might of sorted it myself now thanks. Think it could be the drl power module that's on the back of the lamp cluster. It's only done it twice so I'll let it go completely then buy one. There about £80. 👍
