A3 8p Air bag light on . Any common faults to check?
A3car19tdi
Go to solution Solved by A3car19tdi,
Under-seat connections can be an issue due to dust etc. Worth getting some contact cleaner and giving them a good spray, but DO NOT disconnect OR wiggle them too much, or you run the risk of the air bags going off.
  • Solution
 Far short of getting a new door loom I suppose cut  solder and extend where needed.
Just thought I'd put a few pictures up incase anyone else has this.
Probably explains why the heated mirror stopped working too. Airbag light gone out now (But had to reset with obd2 scanner)
