Boot release with key fob
Hi I have bought a 2016 Q7 but the boot won't open with the key fob . It will open when I press the button on the boot and use the switch in the car but not with the button on the key fob . Has anyone had this problem or knows anything about it .
Has it come with a spare key, if so try it either that first.
As it could be an issue with the key (most likely) or an issue with the receiver.
If bought from a dealer in the last 30 days then the supplying dealer should fix this FOC.
Hi , I have 2 krys and both don't work for opening the boot
