Car Play Suddenly Not working
Hi,
Got an A6 Avant 45TFSI last week and no issues until yesterday apple car play stopped showing, phone still connect and can stram on bluetooth but won't display car play.  It coincided with me both installing a sim car and registering with the my adui app etc but did work for a short while after that.  I have tried removing the phone from the car system and then starting again and car play is ticked in the bluetooth setting on the phone and the phone has the most up to date firmware etc.
It is booked in to Audi but not for 4 weeks and in case it is a simple fix I thought I would ask here, thanks.  I did do some searches first and couldn't find an obvious topic that covers this so hope it's not a duplication.
Thanks Steve
Do a hard reset. Hold the round on / off dial for 15-30 seconds (until it restarts).
CarPlay often does this - black screen / nothing showing.
Thanks I will give that a go, it's not a black screen it just won't load carplay at all
Might be different problem then, but worth a go as it fixes the glitches Ive had.
Does your car show in the CarPlay app in your phone settings?
Yeah I will give it a go can't hurt.  Instead of the Car Play icon on the Home screen I get a Phone Apps folder and when I click in there I can see it says my name and car play but when I press it it goes green, i assume meaning it is connecting, and then after a few mins white meaning it hasn't connected
Phone apps folder is normal. Obviously it should open the car play when you access it.
The question I asked earlier was whether your account was correct in your settings on your iPhone?
settings —> General —> CarPlay.
You could try deleting / resetting it from there.
Hadn't understood what you meant, I just deleted that and the Bluetooth connection and then removed the phone from the connected devices on the car.  Set it up again and it asked if I would like to use car play so said yes and then the same thing again, so unfortunately didn't work.  Starting to def think it's a fault somewhere and not just the "nut behind the wheel"
By the way, wired carplay works fine.
Have you another iPhone in the family? Would be worth trying to set up from another device.
i will see if i can find someone with one
Sorry for the delay, I upgraded to the new iPhone and it works perfectly in the carplay now which is interesting.   Apart from the age of the phone the only difference was that I didn't connect the new one to the car wifi and I did the old one, also the old one stopped working the same day (but not immediately) after connecting it to the car wifi.
