TT Mark 2 wiring harness
Hi do i need to diss-connect the battery while changing the rear lights wiring harness - please.  What i need to do is cut each cable in turn and joint it to the new wiring harness
Hello Gary,
I would seriously suggest you disconnect the battery before doing any electrical work on the car.
What method are you going to use to join the new cables to the old?
