norfolkngood Posted 3 hours ago Posted 3 hours ago Good afternoon one and all. I hope we are all well? Last Feb I purchased a Q3 on a 70 plate which im pleased with. However whilst it has original (Hankook) tyres these are now showing signs of needing replacement due to perishing. I have got various prices, and went to get some Bridgestone Alenzas today, and was advised that as my mileage was 8-10K per year with minimal motorways I would potentially be in the same postion in 3-4 years with tyres perishing and needing replacement whilst still a decent amount of tread. I got prices for Kumho, Bridgestone, Hankooks and Yokahamas, but would appreciate some advise on which ones are going to last longest given my mileage / terrain. The sizes are 235/55/R18/100V Thanks in advance. A.
Magnet Posted 1 hour ago Posted 1 hour ago Hello A ( proper name?) If you are doing 10k/a and expect a set of tyres to still have ‘a decent amount of tread’ after 4 years, then I think you have expectations beyond the reasonable. I just don’t see it, even if you spend on the best. In case it helps:- Based on family experience, if I had a 4x4 type vehicle I would be going with Pirelli Scorpians. I’ve recently fitted a set of Kumho on our largish family saloon. Kind regards, Gareth. p.s. A ? - not too fussed on your choice of forum name.
norfolkngood Posted 1 hour ago Author Posted 1 hour ago 3 minutes ago, Magnet said: Hello A ( proper name?) If you are doing 10k/a and expect a set of tyres to still have ‘a decent amount of tread’ after 4 years, then I think you have expectations beyond the reasonable. I just don’t see it, even if you spend on the best. In case it helps:- Based on family experience, if I had a 4x4 type vehicle I would be going with Pirelli Scorpians. I’ve recently fitted a set of Kumho on our largish family saloon. Kind regards, Gareth. p.s. A ? - not too fussed on your choice of forum name. Maybe I haven't explained it well. If the tyres wear, due to mileage and need replacing that's fine. The tyre shop operative said he didnt think that would be the case, though, and they would perish before tread wore out given my milages. It just always bugs me disposing of tyre with decent tread due to perishing.
cliffcoggin Posted 50 minutes ago Posted 50 minutes ago I have never known tyres to perish as a result of ageing until well over ten years old. Four years at 10000 miles per year is going to wear them out long before the rubber degrades.
norfolkngood Posted 44 minutes ago Author Posted 44 minutes ago 1 minute ago, cliffcoggin said: I have never known tyres to perish as a result of ageing until well over ten years old. Four years at 10000 miles per year is going to wear them out long before the rubber degrades. Existing ones are original ones 2020 and whilst passed MOT in September with a note they were showing signs perishing the fronts have now been flagged red (following further unrelated work) with 24k miles on vehicle. The rears have 5.3mm of tread whilst the fronts 3.4mm
