X111TAV Posted May 10 Posted May 10 Hello everyone, I thought I’ll share something here with people that might experience same problem as I did. Recently I’ve got a message on my MMI saying I have to enter my user login details again for some reason and I was not been able to do that. Every time I was putting in my email address and password, a message would come, saying: You could not be logged in at this moment, try again later. Or something like that. I’ve tried everything, log out from My Audi app, log back in, clear catch on my storage for Audi app, delete the Audi app, add new user, remove user key, literally everything I thought would help. Nothing worked, and I was driving my car under guest user for a while until today when I had enough of it and sat down again and started from the beginning, determined to crack this issue and I succeeded. What I did was: 1. Delete the app on the IPhone. 2. Reinstall the app back on the phone. 3. Reset the password via forgot my password after you type in your username. 4.. Remove the vehicle on My Audi app and add the vehicle back in, remember you need the vehicle identification code to do this. follow the steps from the app to add your car. 5.Factory reset your MMI or reboot to normal mode, you know, two fingers on RH on top of the screen. 6. When reset has been successful, log in with select user, or add new user, login in using your username and the password which you have reset earlier. This is what I did and it helped me to login and my Audi app is working normal too. I hope this will help other people with the same issue I had. all the best 2
Steve Q Posted May 11 Posted May 11 This is fantastic advice thanks for this. I'm going to pin the post for other members 🙂 1
Artc Posted July 3 Posted July 3 HI, Worthwhile trying, but didn't work for me. I redeployed the app and changed the pwd & got as the reset - did a "soft-reset" .. meaning holding the volume control knob for ± 15 secs . When it comes up I see it verifying my original/current key user (lets say XXX) for access ... and then I get the user dialog. XXX is still listed alongside 'Guest' but I cannot apply its settings (tech error) .. I cannot delete XXX .. and I cannot add a new user with the new password: "technical errors" everywhere. The only option I see is do a full factory reset (the nuclear option) .. but I understand I may need dealer approval with registering a new user 😞 So still stuck ... This whole key user thing has always been unstable; I had issues with my last Audi too and had to leave it at the dealer. In any case, if anyone has any suggestions/advice it would be welcome
