Jepor Posted Tuesday at 08:38 PM Posted Tuesday at 08:38 PM Hey all I have an 2015 audi a6 c7 auto s tronic 7 speed , yesterday I got the passenger side outer cv joint replaced, it sorted out the usual cv joint symptom of clicking when turning. Today I noticed something strange , when I put the car and reverse and accelerate the is a clunk noise only once , it then does it when I stop and go into drive , again one singal clunk . The car is driving perfect it's just the signal clunk on initial take off either in drive or reverse. Have to wait to go back to garage . Could it be backlash. It's only come since the cv joint was replaced . Sounds harmless but nervous that it's doing damage . Has anybody experienced this before ? it's like a singal metallic clunk in drive and reverse , nothing while driving after initial acceleration . Thanks
spartacus 68 Posted Tuesday at 09:50 PM Posted Tuesday at 09:50 PM You’re right to flag it. Something isn’t sitting right once the suspension or brakes were reassembled A single clunk could be pads moving in the brake carrier. Were the garage lazy and simply buzzed it back on? A strip down, blow out with compressed air and light smear of ceramic grease would bed everything in. The final torque on the hub bolt is with the wheel still raised, and there’s a sequence. Any other associated suspension links that were dismantled should be checked too. 1
Jepor Posted Tuesday at 10:04 PM Author Posted Tuesday at 10:04 PM Luckily it's going into gear ok so don't think it's the gearbox , it's seems to be when I start to move while in drive or reverse, so it feels to me like something lose and knocking, im starting to think about lose driveshaft bolt .
cliffcoggin Posted yesterday at 10:46 AM Posted yesterday at 10:46 AM John. You have only done one CV joint so I would suspect the other side also needs to be changed. They tend to wear out at the same rate. 1
Magnet Posted yesterday at 11:07 AM Posted yesterday at 11:07 AM Hello John, ’I got the passenger side … joint replaced’. My advice would be to take it back to whoever fitted it - don’t fiddle with it, don’t try to self diagnose it - but take it back ASAP. Please let us know how you get on. Kind regards, Gareth. 1
Jepor Posted yesterday at 12:05 PM Author Posted yesterday at 12:05 PM Thanks for replies , going back to garage today , think it's just the way the drive shaft was reassembled after changing the cv joint . It's only happening on initial movement back and forward . No sound actually going into gear . 2
Jepor Posted yesterday at 03:09 PM Author Posted yesterday at 03:09 PM UPDATE : took the car back to garage , they took everything apart and retightened all the bolts on the inner cv joint and also the cv hub nut , Absolutely no movement on inner joint . Unfortunately the noise still there , on the plus side it's definitely coming from the wheel area not the gearbox , it's there when put the car into drive or reverse and accelerate hard . So at least he was able repeat the sound . He reckons it must be a faulty part out of box , he reckons theres movement on the spline when accelerating, he has ordered a new part and will fit next week when it comes under warranty , he says it's perfectly safe to drive until then . Hoping the new part will solve the problem , he's says that's all it can be as that's all that was changed on the car . It's an SFK cv joint not sure how good they are but he says they are very good parts . 1
Jepor Posted yesterday at 04:47 PM Author Posted yesterday at 04:47 PM Just another enquire , my mechanic is convinced it's the outer cv joint making the knocking noise when accelerating, but everything iv read on the web suggests that this knocking is the inner joint not the outer , can anybody tell me can an outer joint cause this singal knock when accelerating? Don't want to have to go back again if it was the inner after all this.
Jepor Posted yesterday at 04:57 PM Author Posted yesterday at 04:57 PM He also doesn't want to change the whole driveshaft he says there's no need. His logic is the only thing that was changed before the knock came was outer cv joint , so it's obviously the outer thats the problem . Has he a point or am I being paranoid?
cliffcoggin Posted yesterday at 05:32 PM Posted yesterday at 05:32 PM So do you trust Mr. Google or do you trust your mechanic? In your position I would go elswhere.
Jepor Posted yesterday at 05:52 PM Author Posted yesterday at 05:52 PM I suppose my mechanic who's working at it 40 years knows more , also he's covering the cost of the replacement cv joint so not going elsewhere , I can just try the outer and if still knocking i have lost nothing, then move onto inner . My question is can the outer cause this knock noise ? I thought it would just be a clicking while turning .
cliffcoggin Posted yesterday at 06:00 PM Posted yesterday at 06:00 PM 4 minutes ago, Jepor said: My question is can the outer cause this knock noise ? I thought it would just be a clicking while turning . No, it can knock in the straight ahead position, though it is always worse when turning.
Jepor Posted yesterday at 06:04 PM Author Posted yesterday at 06:04 PM Oh ok thanks , I took it to him with a clicking when turning left , got it back and the clicking was gone , but now have the single knock when initial acceleration in drive and reverse . So hopefully the 2nd new outer cv joint will fix this .
spartacus 68 Posted yesterday at 09:36 PM Posted yesterday at 09:36 PM SKF is a quality part. Stick with your mechanic, if you trust them, then that counts for a lot. I’m sure you’ll get to the bottom of it.
