Air bag light.
Afternoon all, looking for help.
Had the airbag light on dash, looked for solution on forum’s, done everything suggested, lastly to disconnect battery. Which I have now done. On reconnection. Air bag light, ldw , traction control, tyre pressure warning etc, etc.
Now can’t do anything via MMI or is it a trip to Audi. Car 21 plate saloon.
Thanks in advance.
Solved by joe6
Hi, I purchased a car soft audi v3 old reader and it has option for resetting and reading airbag codes was only £199 on amazon, something like that might be worth a try
  • Solution
Thanks in advance.
Often get multiple faults after disconnecting the battery. Need to leave it disconnected for about 30 mins. Usually clears after driving a couple of miles. If the airbag light stays on a useful fault code reader is OBDeleven that also resets fault codes. Basic version is about £50 and pro version about £80. Since dealers charge about £100 to run a diagnostic they are worth considering.
