Grettings!
Im having an issue with my audi 2010 a3 s3, 2.0 petrol, s-line.
When the weather is hot or the car gets hot the engine cranks and doesnt start. It also shuts down suddently and occasionally there are no dashboard lights at all.
After it cools down it starts and run fine.
I connected my oschiloscope to the battery terminals and while engine cranks i noticed a drop in voltage everytime the engine rotates. It only does a few rotations and then stops. Max voltage drop i measured was 5v.
I also used a clamp metter during cranks and got 59 ampere.
Any iddea why this happens.
I have tried a new battery.
30 minutes ago, edmiri said:
That doesn't explain the no dashboard lights issue.
Sorry if missed that bit. In that case I wonder if it's a problem with the imobiliser which is built into the instrument cluster.
The clusters are known to fail but can be repaired for around £300
This would be the only issue or its an issua in adition to the ones you mentioned? Could a defective imobiliser also prevent the engine from starting and also turn off the engine suddently.  Those happens when its hot weather only.
Yep imobiliser definitely can.
I noticed something. The ingnito key is sending unregular voltage to the relay. When i feed the relay with full voltage during ignition the engine starts without cranking.
So could be the key then. Have you got a spare?
The problem could be the ignition switch or the key?
Hello Edi,
How old is the battery?
Have you had it checked under load conditions?
When you say you have tried a new battery, was that a ‘new,new’ battery, or a used one, and what battery is currently fitted?
Have you checked the engine earths?
Regards,
That's a good point, it could be.
17 hours ago, Magnet said:
Hello Edi,
Regards,
Engine earth is directly connected with extra wire.
