It's summer and my roof is ironically unusable; ran a vcds to figure whats wrong and still lost.
Has anyone one else come across / solved this issue with their convertible before?
WhatsAppImage2025-06-25at09_30.35_15594517.thumb.jpg.59678c1ab019b6b44345840875f9f2e5.jpg
7 minutes ago, Steve Q said:
Can you lower it manually?
Hi Steve,
I'm sure theres a way to manually close and open the roof however I haven't tried it.
I believe the issue is related to the switches inside the latching mechanism that are !Removed! - the motor has rapidly degraded in speed to open/close as well.
The manual control should be in the boot on one of the side panels.
I think you're right with your diagnosis
If I can lower it, what would this do?
Micro switches are often the culprit with these. Are you able to tackle this yourself if you know what switch/s are at fault?
If not, I would be searching Classic car trimmers in a doable radius - they are often versed in issues with such things.
‘If I lower it (manually) what would that do’?
The same end result as if you did it electrically!
Regards,
Just one way of you getting the roof down to enjoy the sunshine
