Craig stuart Posted 4 hours ago Posted 4 hours ago Hi folks can anyone recommend an aftermarket undertray iv just noticed that mines has been cable tied up and has come apart at the front any help would be greatly appreciated. Cheers
Steve Q Posted 3 hours ago Posted 3 hours ago It might not be as bad as you think as the under tray is in two parts. Front for the engine and rear for the gearbox. Looks like it's come apart at the join. 1
Craig stuart Posted 3 hours ago Author Posted 3 hours ago Yeah the rear part has come off at the front section but the front part the screws are very rusty and loose really want to get it changed. Have seen some parts on eBay but unsure if correct part. Thanks again for time its greatly appreciated 👍
Steve Q Posted 2 hours ago Posted 2 hours ago You're most welcome. You need to make sure you get one from the same engine and gearbox as yours as the undertrays can vary depending on the engine or gearbox due to there differing in size etc.
Craig stuart Posted 2 hours ago Author Posted 2 hours ago Thanks probably best to remove first then have a look cheers for your time take care
spartacus 68 Posted 1 hour ago Posted 1 hour ago If you remove the part, there will be an Audi part or VAG number on it. To be honest after market undertrays are cheap plastic. Search on eBay for genuine part, or a breakers years. One word of warning if you find anything on breakersyard.com, utter charlatans. 1
Steve Q Posted 1 hour ago Posted 1 hour ago 30 minutes ago, Craig stuart said: Thanks probably best to remove first then have a look cheers for your time take care You're welcome 🙂 please keep us posted on how you get on 1
