wheel and tyre size ??
hi i am looking to change my 17" wheels on my audi a1 2015 s line for 16" ones 215/45/16 with the same p c d of 5x100 will they fit ?? and will they put my speedo out of sink ?? i cannot find audi ones in good condition and at a good price so i thought to ask if this can be done . thank you for any help  cheers
The all important consideration is the ‘rolling diameter’.
You don’t tell us the tyre sizes of your current 17 inch wheels.
Please let us have that information so we can offer you best advice.
Regards,
yes sorry i did not include size  it is 215/40z/r17 i have been told there are a few other wheels and makes that can be fitted that will not effect my speedo ?? is this correct , thank you cheers
If I may expand upon Magnet's reply, he means that if you change to 1 inch smaller wheels you need to fit 1 inch larger tyres in order to leave the overall gear ratios unchanged.
But that is not all. The amount that the wheels are offset from the hub (or dished) also needs to be unchanged in order to avoid the tyres hitting the suspension and bodywork. That's why I can not be certain Ibiza wheels will fit. Probably they will, but I'd want certainty before spending money on them.
so if i get audi a1 wheels with same p c d of 5x100,  what tyre size that you can recommend    that i can fit to maintain correct speedo reading  thank you for any help cheers
Thanks Frank,
Have you worked out the economics of buying different  size wheels and then appropriate tyres vs. having your current wheels refurbished?
it is not because my wheels are damaged , i just want to change them to 16" ones to get a better softer ride , 17" low profile ones give you a harsh ride , spoils the fun of the audi a1
Hi Frank,
I agree with all the comments you've received so far, but cant emphasise enough the importance of the offset. I have gone through a wheel changing exercise myself on my Audi and it took me months and months to find wheels I liked and that would fit. The offset can determine where on the hub the wheel will sit and whether its likely to fowl any brake or suspension components. Fortunately there are easily accessible websites that can give you a guide indication of how your new wheel will fit, they will ask you for your existing wheel fitment and the new wheel fitment your proposing. They will ask you for the existing and new wheel radius and width, and also existing and new tyre sizes. They will also ask you for the offset of both existing and new wheels. The offset is often referred to as the 'ET' followed by 2 numbers and this is usually stamped in the wheels casting on the back of the rim. Just as an example my existing wheels had an offset of ET31 (stamped on the reverse of the rim) and the new wheels I was proposing had an offset of ET40. If you want a smooth and not so bumpy ride, try and and avoid tyres with a profile of less that 40.
Hope this is helpful
Thank you Frank,
Your case is unusual. Usually,owners want to buy larger diameter wheels, because ‘they look better’!
Ride quality is obviously important to you ( and would be to me), but in effect, you have bought the wrong car by buying an S.Line, which has inherently harder suspension. My money would be on the likelihood that you bought the car on ‘looks and toys’, which Audi translate into ‘owner also wants roadholding at the expense of ride quality’.
One other factor to consider is whether your current tyres are extra load (XL), since if so, this will aggravate the already harsh ride.
Please let us know.
On 6/26/2025 at 6:23 PM, Magnet said:
Thank you Frank,
Please let us know.
the hard rise i am used to most of my prev cars have had it ,  ie /golf tdi, seat frtsi all   have  a hard ride and road holding superb, but the road noise is excessive with the audi a1 i have bought ,i have had suspension etc all checked over (  no faults i have read that the 16" tyres with low road noise work better than the 17" inch ones , thank you for your reply
So it’s no longer ride quality that dissatisfies you, but road noise.
What tyre brands and types do you currently have fitted?
You may find that changing wheel sizes may not give you significantly less road noise, due to the the inherent likely-less insulation on the A1.
i have insulated the total floor and also the plastic wheel arch covers with
noise deadening sheets, also undersealed the wheel arches, and covered the boot, but it is still loud, ,when i drive on a good piece of road it is great / hit a rough part of road it is terrible , i must say for an upmarket car brand they  have not  thought of  noise comfort  , for  all the gadgets and style this car has , it  is a poor show for audi,. i am verey disappointed in the car because of this .    reading on other forums, by changing wheels to 16" ones seems to reduce the noise , so thank you for all your help i will let you know if and when i change them how i got on  cheers
yes everything has been checked it seams to be the tyres ,being 17" low profile ones, that is why i am looking for 16" ones and wheels to try i have soundproofed the floor/under wheel arches and boot and bonnet , but on a piece of rough road (normal in this country )the road noise is verey load ,on a smooth road it is great ??
You didn’t let us know what tyre brands are currently fitted Frank.
Have you checked the listed noise rating on them?
How much tread is left, since tyres generally get noisier as they wear?
You really do need to give us all the information- problem and what you have already done to try to solve it, otherwise we will end up suggesting you do what you have already done - again.
Regards,
not as yet still trying to find answer
hi everyone i have an audi a1 2015 tfsi with 17" wheels and tyres  p c d 5x100  i want to downsize to 16" wheels and tyres 5x100 what is the correct tyre size to maintain the correct speedo reading i have been told that 215/45/16 is about the best size ( speedo out a small amount )if anyone knows of any other ones that will do please let me know thank you
Moderator's note. I merged this originally new post into Frank's previous topic on the same subject.
Clifford Coggin.
Frank, it would be good if you could take time to answer the questions asked in my post of 4th July before further muddying the waters with other associated questions.
Regards,
i thought i had.     i said,  no problem with  tyres only too big   ,this creates excessive road noise , so i have decided to downsize to 16" ones i only want to know if 215/45/16 ones are the best match as regards to speedo readings ,as now the ones on my car are215/45/17 and i am having difficulty in finding the on web as most ones for sale are 205/55/16, cheers, i have checked noise level for tyres and it is ok , they are all new , i have fitted sound dead material around wheel arches and wheel arch covers frount , rear arches with same  material but most of the noise is from the frount (tyre road noise )
my audi a1 tfsi 2015 i have checked the tyre and wheel  calculator on the web and it says it is ??are they wrong or right ?? i was just asking if there are other wheels and  tyres that will do the same as i would prefer to put 16" wheels and tyres in place of the 17" ones
Edited by frankval
Any system which tells you the same tyre width and profile for a 17 inch wheel will be an acceptable combination to fit on a 16 inch wheel, then fit on your car, is incorrect, or you are interpreting it incorrectly.
