A4 2.5tdi high pressure fuel pump/edc
Hi,
First post, sorry if it's help needed...
After a disastrous edc short during a routine service (not by my long time mechanic) I had the EDC unit repaired but I've had continuous running problems since May.
The car is now with a different mechanic who tells me the injection pump itself is damaged so I need a new/refurbished unit.
I'm having no luck in finding the pump part number I need so I can buy a new pump, so could anyone help with what the correct part number I need please?
2003 A4 avant 2.5tdi quattro. It's an auto if that makes any difference.
Many thanks in advance
Richard
3 hours ago, richard j thomas said:
Hi,
Richard
Hi have you checked the lift pump in the tank, if you monitor its volume at idle and its around 5-600 the pump may well be on its way out.
Hi Steve,
Thanks for the reply.
I’m not entirely sure what the garage that currently has the car has checked to be honest, other than they’ve said the injection pump is damaged.
48 minutes ago, spartacus 68 said:
Double-check here based on engine number + auto. Price will be prohibitive - so source second-hand.
https://www.lllparts.co.uk/catalogs/audi/RDW/A4Q/249/1/130/130025
Rich,
That's helped massively, thank you.
My engine code is BAU, pump numbers are 059130106 and 059130106LX, could anyone explain the difference if any please?
2 hours ago, richard j thomas said:
Rich,
There's a diesel injection specialist in Aberdeen. Used them years ago - Airylea Motors. Very knowledgeable - they work on injection pumps across cars, marine, agriculture, etc. Had an old Audi 80 there years ago. Speak to them as the old pump might be able to be refurbished. https://www.airyleamotors.com/
A 1.9TDI is completely different to V6 in terms of access and how to remove. I used to have a 2.5 V6 quattro (150PS). Cracking cars.
Edited by spartacus 68
