A3 8P 3.2 VR6 Coolant Leak (Part Number help)
Got a VR6 3.2 A3 8P, noticed a small coolant leak coming from this rubber bung (a pin hole)
Can't seem to find the part number for it, would anyone be able to assist?
Solved by pocketrockets
Is it the blanking plug next to the green coolant temperature sensor?
If you can't find a new plug, get a second sensor to plug it, it's held in with a fork shaped clip,
not sure on the colour, but it's a plug for sure
do you know a part number for the sensor at all? or know exactly what the part is that has the two outlets (sensor on the left and bung on the right)
  • Solution
Thanks for your help
Think i've found the rubber bung now
Part number - 357121140
