TPMS valve stems and Ring RTC6000 air compressor
Hi chaps
I'm hoping some of you chaps might have some solutions to my issue.
I have a Ring RTC6000 air compressor that I use to set the tyre pressures. This worked perfectly until I had Advanced TPMS fitted to the car a few months ago. It seems the valve on the air compressor is that little bit too short as when I put air into the tyres and then unscrew it, air leaks out too quickly to complete the unscrewing action resulting in slightly too low tyre pressures - should be 36psi on front and 32psi at rear but when I do this, and then check the Advanced TPMS pressures, they are at 32psi front and 30psi at rear, not what I wanted to see! I've had a look at the TPMS valve stems and compared to a normal tyre valve stem they're quite short which might be the problem.
Has anyone ever come across this issue and if so, was there a solution?
Thanks,
Alex
Hello Alex,
I have found Ring appliances to be better than most, but I would never depend on pressure gauges used on any brand.
Solution:- By yourself a c£10 digital tyre pressure gauge from Halfords, inflate the tyres to a few p.s.i. over the required pressure and reset with the digital gauge - which is capable of controlled deflation.
Job sorted!
Regards,
Hi Gareth
😆😆😆 Don't I know it!
Got it, thanks. I'll pick one up soon.
Thanks,
Alex
