Audi A5 Manual - Gear Stick Vibration
Hi.
I recently purchased a 2017 Audi A5 S line Manual and have noticed that the gear stick has quite a lot of vibration going through it especially when going on uneven road surfaces. At Idle it does not have the same level of vibration. Has anyone ever experienced similar or know if this has the potential to be an issue.
Thanks
1 hour ago, Matthew Clarke said:
Hi.
Thanks
Hi its probably the rear gearbox tail shaft mount quite a common problem also check the engine mounts for oil leakage.
Thanks Steve.
