Cam shaft sensor
I don’t have any online picture info available but where is the cam shaft sensor located on the 2.0l TDI 190bhp 2014 Avant?
mine is coming up with a error code relating to the cam shaft sensor so looking at swapping it out.
Regards.
Solved by spartacus 68
No one!
13 hours ago, Steve Q said:
Have you looked on YouTube?
Yes could not find any that relate to the same sensor location hence the question here.
14 hours ago, cliffcoggin said:
My word. Aren't you impatient. Learn some patience and wait a few days before demanding attention. We all have real lives outside the forum.
Impatient yes because I needed a fix on the only day that I had free to attempt to fix it before I need the car for work.
Hence my so called impatience “not”.
  • Solution
If CNHA engine, it’s located on engine block cylinder head. Also known as hall sensor (14) on this link.
https://www.lllparts.co.uk/catalogs/audi/RDW/A6/717/1/103/103052
Crankshaft sensor here too (15) near bell housing: https://www.lllparts.co.uk/catalogs/audi/RDW/A6/717/1/103/103050
Fantastic, just what I wanted….
Many many thanks.
