Aux water pumps
Hi all, had water pump & cam belt replaced 3 weeks ago, no problems for a few days then EML came on, had car plugged in which showed code P261AOO (auxiliary water pumps open circuit) had both replaced with genuine Audi parts, had light turned out, drove for 1/2 hour, switched off, restarted car after 5 mins & light back on. Any ideas.
A4 Quattro avant 2015
Hello Colin,
If it were mine I would be returning it to whoever did the work for you, and asking them to sort it.
Any attempt to DIY it is likely to end up with dismissal due to you fiddling with it.
Regards,
