A3 Sportback (8PA) 1.8 TFSI PCV Valve replacement
Hi Guys,
I am trying to find a replacement for the PCV valve as it has rough idle and checking the PCV valve the diaphragm has a split in it, part number on current one is 06H129101B (Image attached) but I cannot seem to find a replacement anywhere, did an AI search and it suggested 06F129101N or 06F129101R but these look a bit different as they have an extra port at the end.
Any help would be greatly appreciated.
13 hours ago, Maze said:
Hey! Sorry if I'm reviving a dead sub, but I had this exact issue. I did manage to find one although it was very expensive:
https://www.oemvwshop.com/06h129101b-pressure-relief-valve-p358193/
The gaskets for the ones you find on eBay do fit however, you just need to cut off the extra port.
Hi the part you have found is incredibly cheap for a genuine part, try Audi at about £200 and thats if you can get one from them.
ooof! £200 is wild for what it actually is. I did purchase the part linked and have been running it for a few months now with no issue. It just stings when you see the alternate part for the later versions of this engine going for £25 - £30 for well known aftermarket manufacturers. Either way I hope it helps with OP!
