What to do, poss head gasket?
So my 2013 1.4tfsi has been into 2 garages for coolant loss & random "Stop engine low pressure" light.
First garage said head gasket & quoted £3,055 for the work, but they added w/pump & belt plus timing chain on a 60k engine.
Second garage concurred but refused the job saying Tfsi engines were rubbish & couldn't guarantee it was head gasket alone! And fitting another engine would cost 3-5k!
Third was online community who all say both are a joke, & a few mentioned the intake manifold cooler as possible reason?
So sniff test done & failed, compression test & failed (none said what readings were or what cylinder(s) )
Now it's losing coolant rapidly, however there's no white smoke, oil is still clean & runs absolutely fine with no misfires.
Car on a good day could fetch 5-6k due to improvements made over 4 years i've had it. Now stuck on what to do or go next? I live in Crewe & no particular VAG specialists nearby other than official garage.
Edited by cockneyrick
Richard.
Are you really referring to low coolant pressure warning? I suspect you mean low oil pressure.
The 1.4 TFSI engines of that era were notorious for their skinny piston rings causing dramatic losses of oil which would explain the low compression readings and failed sniff test. The only realistic solution is installation of redesigned pistons and rings at great expense. Whether the coolant loss is related I can not say.
Your first garage was right to suggest renewing belts and water pump at the same time because they would be due in 10000 miles and would need another engine strip down to install them, so it is cheaper to have the lot done at the same time.
In its present condition I doubt that the car is worth more than £1000. Do you love it enough to spend several thousand pounds on it?
