A/c not working
Hi all ,new member here ,couple of questions first my Aircon has stopped working,I bought car back in Feb from dealer in Stockport had issue with adblue tank going home ,(live up in Scotland) got fixed under warranty and got Aircon regass as well ,was working now not light stays on whereas before didn't,any ideas ?also being the permanent quattro looking to change the diff oil anyone know what spec it is and how much I will need thanks
MODs can you move this to B9 forum please.
Car will need scanned with VCDS to see what’s going on. Rear diff gear oil should be good for 100k miles, but no harm in changing it. Double check this part number, with Audi or a motor factor with your registration. G 052 145 S2. Should take around a litre.
Sport diffs or Haldex version use a different specification. From my understanding it’s around a litre. You’ll need to check the Allen key fill and drain plugs for size. Pretty sure they are 8mm. Use new plugs (come with thread locker). Tighten to 16Nm of torque. Note they don’t sit flush with the diff. Always pull fill plug first.
The refridgerant gas has probably leaked out from a hole or a worn pump seal. Get the system pressure tested for leaks, and repair as necessary, before having any remaining gas sucked out and replaced with the correct weight of refridgerant. I suggest using an aircon specialist rather than an Audi dealer.
