Battery for my Audi
Hi, this maybe a sill question!!! I need to change my Battery in my 60 plate Audi A3, the guy in the shop said there is 2 types, one for stop start car and a one without (big difference in price). My car dosent seem to have stop start, because it dosent do it!! But the guy in the shop says it can turn itself off!!! There is nothing on the current battery to say its a stop start battery !!! Guy in shop says if you use a standard one in a stop start in can effect the ecu, so some functions wont work correctly.... Any help would be appreciated...
Hi ring the dealers and ask if your car was fitted with stop start, you will have to give them your VIN and if its not equipped with stop/start you are away, only piece of advice is buy branded and not some random make of battery that is dirt cheap and won't last long, the battery will need to be registered to let the ECU know it has a new battery.
The stop/start system may be present in your car, but if the battery is defective it won't work. As Steve said, find out if the system is installed.
Whatever type of battery you fit ensure it is coded to the car.
Thanks guys, how do I get the battery coded to the car please??
It needs to be done using a decent code reader & diagnostic machine. If you don't have access to one, most garages and battery suppliers will be able to do it for you.
