Engine whirring noise
I’ve noticed recently that I’m getting a whirring noise between about 2-4 rpm when the cars up to temp. The warmer it gets the more noticeable it is. I thought it might be something to do with the drive train etc but when it’s happening, if I disengage the clutch and the engine drops to idle the noise goes away. Bring the clutch pedal back up again, noise returns? Sounds abit like a wheel bearing
Hello Dan,
I guess your description is taken as an in-motion symptom.
What happens if you get the car up to operating temperature preferably after say a 5+ mile run, then at standstill, increase the revs and hold to a steady 3k and check the existence of any noises with clutch pedal not-depressed and depressed?
Regards,
