Engine management light and limp mode??
Ok guys... i was sat at traffic lights and when i set off it went into limp mode and the engine management light came on? I pulled over and turned off the engine and re-started it and it was fine again? This has happened a few times. Its been on the diagnostics and it came back as air flow. The garage has tested the Maf sensor and said its fine. then they took off the egr, took it apart and cleaned it out and it still had a problem so they have put on some pipe for the turbo they had to order from the main dealer and thought they had fixed it! But its still happening?? Any ideas anybody?
Hi Rachie, did the garage give you the fault code that came up on diagnostics?
  • 2 months later...
I mate try your turbo release valve just had my 2006 2.0T in E.M.L came on and reset itself over night my garage pluged it in to there fault reader and came up with that code it could be the seal on the T R V  Andy F
