hazyfantazy Posted September 5, 2016 Share Posted September 5, 2016 AUDI A3 TDI 2007 sometimes when cornering a red oil light comes on when i am not sure if this is the oil low warning or oil pressure light it happens intermittently and is accompanied by a beeping warning it can happen at low speed and seems to happen most often when the road turns one way then the other the car has just had a oil service and the oil level is perfect Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 6, 2016 Share Posted September 6, 2016 Hi Mark I would suggest it is a faulty sensor or wiring connector attached to it. If the oil level is fine and not too thin (washed down with fuel) then it's worth taking a chance on the sensor. I would certainly get it checked sooner than later just in case. Let us know how you get on with it Cheers Trevor Quote Link to comment Share on other sites More sharing options...
