Sign in to follow this
KAJ
Electronic Handbrake help!
Hi, i have an A3 Sline Quattro, manual transmission with an electronic handbrake...just after some advice...
When starting the engine and going to pull away, I am finding that the brakes seem to be sticking, I'm having to rev quite a lot for the electronic handbrake to finally release then the car sort of lurches forward.  It doesn't happen all the time, it's intermittent, but has happened when pulling out of junctions, setting off from traffic lights, and has even happened when reversing then changing to first gear and going to set off.   When the car is behaving as it should, it reaches bite point and releases the electronic brakes smoothly and with minimal effort...normal basically!
My previous car ( Nissan) had an electronic handbrake which worked without issue, and I've owned A3s in the past too, again without issue.  I always have my seatbelt on and the doors closed, so it's not an issue with that.
Any advice or info would be greatly appreciated!
Share this post
Link to post
It is possible that the pistons and windup mechanics needs a clean . Also does it feel on both wheels or one ? It might be one of the epb motors failing. Have you had vcds scan to see if there are any faults ?
Share this post
Link to post
Hi, thanks for your reply!  I've only owned the car for 7wks, it was an ex demo car at an Audi dealership.  I've had the car into my local Audi dealership, who found a fault adjusted the sensors, which seemed to work for 2weeks, but then the 'sticking' started again.  After lots of backwards and forwards with the dealership I purchased from they eventually came to collect the car and left with me a courtesy car whilst they took my car for investigation.  The courtesy car (A3 saloon with electronic parking brake) was absolutely fine, no issues with the parking brake.  The dealership told me they couldn't find a fault but had changed the rear brake pads and discs as they were blue from overheating, which suggested it had been sticking.  I got my car back and again all seemed great, until 3weeks later, it starts sticking again!!!  It's just so frustrating.  THe dealership are now getting snippy with me and telling me there is no fault as they couldn't be find one when they took the car, be don't seem to be understanding that it's intermittent- for example, it was sticking this morning, but driven perfectly this afternoon.
thanks, Kirstin
Share this post
Link to post
I have only had my car for a few weeks. A3 TDI S line Quattro. I have exactly the same intermittent issue. It is going in to the dealer's next month to get checked.
I also have an issue with the gearbox being very notchy especially going into 1st, 2nd and 3rd.
Dave
Share this post
Link to post
Car was in at dealer's recently.
They "reset" the handbrake and it's been better but still stuck once the other day. It's been alright since.
The gear changes are very notchy in 1st, 2nd, 3rd, 4th and reverse but they reckon that is normal. I do not agree and will speak to Audi HQ about it.
There's a very faint whine too. I have only heard it on a couple of occasions on a very smooth quit road. They said is from the haldex and is normal.
The mmi and instrument cluster flicker intermittently but they didn't see it so I will monitor it.
Is the whine and gear changes the same in other folks cars??
Share this post
Link to post
I've got a 17 plate A3 Quattro and have had intermittent issues with the handbrake sticking since i bought it (new). When I try to pull away the handbrake sticks. This can be when i am starting off or pulling away having engaged the handbrake (eg at traffic lights). Car has been in to garage once and they couldn't detect a problem. It is really intermittent. but both an Audi employee and RAC have seen for themselves there is an issue.
Must admit it's put me off Audis....
any advice? and is it worth returning to the dealer?
Share this post
Link to post
Hi Kate,
i had had a very long battle with my A3 Quattro.  The dealership I purchased from denied all acceptance of there being a fault so I took it to Audi UK.  My local dealership (50 mile round trip away!) were great, but said they had to witness the fault for themselves before the warranty would cover it so it took a year in total of too-ing and frowing as the fault was intermittent.  Things reached a head when it faulted so much that I couldn’t release the auto hand break at all from a set of lights on a national speed limit dual carriageway, and a lorry travelling at 60 mph almost ploughed into the back of me - the most terrifying moment of my life! I rang Audi assist and had the car retrieved and taken to the local dealership.  They couldn’t release it either so sent a report to Audi uk...who then admitted they knew about the fault but do not have a fix!! Because of this, the purchase dealership had to buy the car back off me for full purchase price minus mileage.
Audi UK don’t have a fix, so take your car back to the dealership, contact Audi uk and stand your ground.   Good luck 😉
Share this post
Link to post
I am still getting this intermittent issue. It's quite dangerous and has nearly caused an accident a few times. The dealer has had it in on several occasions and witnessed it but still no fix. It has now caused a shudder from the clutch and flywheel and it was in to get an oil leak checked recently and they reported that the rear disks and pads needed replaced as they were scored and worn. Nearly £400 to fix.
Audi UK are not interested.
Share this post
Link to post
Car in again today. Still no fault found. Still no fix.
  • Sad 1
Share this post
Link to post
Loading...
