Gary123 Posted January 25, 2018 Share Posted January 25, 2018 My engine oil light has come on saying the level is low. What is the best oil to use I m getting mixed information between 5w 30 and 0w30. Is there much difference and is this normal after about 10,000 miles ? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 26, 2018 Share Posted January 26, 2018 Hi Gary 5w 30 is correct. Here is the info on Audi's website: https://www.audi.co.uk/owners-area/servicing-maintenance-mot/audi-oil.html Audi recommend Castrol edge professional long life 3. When my dad had a 1.6tdi a3 8v he found it used quite alot of oil too. Hope I've helped :) Cheers Steve Quote Link to comment Share on other sites More sharing options...
Fatbloke Posted January 26, 2018 Share Posted January 26, 2018 I use this in my Skoda VRS and A3 tdi. Shop about and you may get it a bit cheaper. This is also what the Skoda dealer's use. https://www.ebay.co.uk/itm/Quantum-Longlife-5W-30-Fully-Synthetic-Engine-Oil-5-Litre-Bottle/253386748394?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D49896%26meid%3Dfd41d23874924050a1eec57347565819%26pid%3D100011%26rk%3D2%26rkt%3D12%26sd%3D222183174678%26itm%3D253386748394&_trksid=p2047675.c100011.m1850 Quote Link to comment Share on other sites More sharing options...
Gary123 Posted January 26, 2018 Author Share Posted January 26, 2018 After abit of research online it seemed to suggest 5W 30 but called my local dealer and they said they use and recommend 0w 30. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 26, 2018 Share Posted January 26, 2018 1 hour ago, Gary123 said: After abit of research online it seemed to suggest 5W 30 but called my local dealer and they said they use and recommend 0w 30. Which is weird as its the opposite of the Audi website. When I worked in a volkswagen service department we used 5w 30. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 26, 2018 Share Posted January 26, 2018 I too would go with 5w/30 and indeed I would certainly agree with the use - and use myself- of Quantum (Longlife) as David ( Fatbloke) recommends. If this car has covered 10k miles without topping up the oil ( on Longlife service schedule I guess) then it's certainly doing very well in terms of it's oil consumption, since I would guess it now requires just 1litre to bring it back to the full mark. (But check the handbook). Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted January 27, 2018 Share Posted January 27, 2018 Is it a diesel ? If so oil standard for audi is 504.00/507.00 . 5w 30 will be fine Best brands are liquid moly and motul Re longlife... if you want to enjoy the car and keep it longer , stick to oli and filter changes every 10k Quote Link to comment Share on other sites More sharing options...
Gary123 Posted January 28, 2018 Author Share Posted January 28, 2018 On 27/01/2018 at 4:08 PM, niedzial1983 said: Is it a diesel ? If so oil standard for audi is 504.00/507.00 . 5w 30 will be fine Best brands are liquid moly and motul Re longlife... if you want to enjoy the car and keep it longer , stick to oli and filter changes every 10k Its petrol. Quote Link to comment Share on other sites More sharing options...
