Hi I'm a new member and a owner of a Audi S8 D3. I'm a die hard Audi fan and have been for years or even decades.
I needed some advise and thought this would be the ultimate place to share my problems with. Lol🤗
So where do I start. I purchased this car a while ago as a project and have now started to look into it. It's been stood since 2007 and has covered around 5thousand miles. 5k. The previous owner had it parked for 10years as it had an electrical fault and some damage which was caused in 2007. After reading on various websites, Ive concluded the steering column to be faulty as vcds is showing steering lock actuator n360 open circuit fault leading me to believe it needs a column. The car accepts the key but there is no ignition lights on the dash.
Hopefully when I've sorted this problem I will have to start it at some point. What would be the best procedure. I have already dismantled the front end hoping to crank it by hand for the first few revolutions what should i do as I don't know the state of the engine. If it's seized etc. I don't want to damage what could potentially be my car i keep for life.
Any help would be appreciated. Thanks
Welcome to the forum, you'll find the members on here are a friendly and helpful bunch :)
Wow, it's been stood virtually since new! What's the cars story?
Plus you have to wonder why it was parked up at a year old with a steering column fault and not taken to the dealer under warranty for repair?
It does sound like it's the column at fault and I wonder if it can be repaired? Also I'm assuming you've ruled the keys out as the possible cause?
I say this as they may need reprogramming if the car and keys have sat for over 10 years. This would also be a cheaper option than replacing the column.
I'd say you'd be right to do a crank by hand and you'll quickly know if the engine is seized. Once you've established it is free then I'd carry out a full service on the engine including a new battery, cambelt and water pump + tensioner.
Once you've don't that then it's worth seeing if it'll start normally. Fingers crossed :)
Keep us posted on how things progress and we'd love to see some pics of your a8 :)
Thanks Steve.
The car had sustained some damage at the front and was subject to a category D in 2007. It was bought by a chap who had left It in his barn for over 10 years. He had some health problems (at least what he told me ) and tried a few electricians but no success. My main concern is the engine not seized etc. I have removed the column and I'm waiting to see if a friend can swap the file from my car to a new steering column which I bought of eBay. Holefullyvthat may work. If not it's £1020 from audi plus coding. But obviously don't want to fork out 1100 pounds if the engine is shot . I will hopefully keep this detailed and take pics. Fingers crossed the engine isn't knackered, can't take anyone's word on it unless I take the measures to check myself.
I'm going to drop some oil in the cylinders today and let it soak in for a cpl days and manually turn it over by hand. imageproxy.php?img=&key=1c45eb7422604623
Steering column
You're welcome :)
The car must have taken a fair wack for it to be classed as a cat d! New the car would have been 80-90k new so it would have had to have sustained damage of approx 10-20k I'd say at a guess. For total loss insurance companies go up to approx 50% of the cars worth. At a guess at a year old the car would have been worth approx 40-50k depending on exact spec. So total loss would have been approx half that.
Hope I'm not boring you!
That's a good idea with regard to the cylinders. Fingers crossed it's not seized. I do hope the steering column is a simple fix too. £1200 for a new one from Audi is extortionate!
Lol. For a small module that has gone down the pan. I'm mechanically minded so I do most of the work myself. Spoke to a few other guys who had to fork out over £2800 thats just daylight robbery.
I'm gonna wait till Mr sunshine visits us again in the uk, before i give it a crack. Will keep posted I'm sure once it's done some poor chap whose going through the same dilemma will read this post and might get some relief from scouring the net
So, I stripped the steering lock and sent it to Tom at Speedo solutions to have it remanufactured, along with the kessy and a key. Hoping he sorts it. Heard a lot of good things about the chap.
I also filled the cylinders with marvels magic oil and let it soak for a few days.  Turned engine by hand wasn't seized so that was a result.
That's great news about the engine :) let's hope Tom sorts the steering and you'll have made great progress :)
Would love to see some more pics of the a8 :)
  • 4 months later...
So a quick update. Installed the new column. Had it coded. I'm still having the same problem. No lights no ignition.
I did manage to get the car to crank over. But only through vcds.
I go to 05 Acc/start module. Put in my security code, which then allows me to do out put tests.
The out put test
1. Unlocks the column
2. Switched on terminal 15, which allows me to get all the dash lights etc. On. Which then allows me to start the car which starts for a brief 2 secs. Then dies out.
My vcds codes are as follows.
The codes that I think are related to start problem are ECM not adapted and Transmission ECM not adapted.
I'm in the right direction and have come along way, I just need some expert advice from you guys to get me a little closer.
Sunday,05,August,2018,19:05:29:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ4E47N005512   License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 25 34 36 37
          38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUZZZ4E47N005512   Mileage: 7850km-4877miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
53-Parking Brake -- Status: Malfunction 1010
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: Sporadic communication error 1000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 4E0 910 552     HW: 4E0 907 552
   Component: 5.2L V10/4V FSI    ª0040
   Revision: 5AH11---    Serial number: AUX3Z0F6399878
   Coding: 01060003190F0160
   Shop #: WSC 02313 785 00200
   VCID: 5FCDC5598EEC0FB996-800A
12 Faults Found:
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 35
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:32:00
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.430 V
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 002 - Signal too High
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:32:02
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 30.0°C
                    Voltage: 11.938 V
012370 - Starter Control; Returned Message
               P3052 - 001 - 50 Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:42:05
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Voltage: 11.684 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:42:47
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.303 V
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:42:47
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.303 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:42:48
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.684 V
053250 - Please Check Fault Codes in Comfort System Control Module (J393)
               U1002 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:49
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.557 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:57:35
             Freeze Frame:
                    RPM: 1643 /min
                    Load: 45.9 %
                    Speed: 0.0 km/h
                    Voltage: 10.922 V
004200 - Intake Air Switch-Over Valve (N335)
               P1068 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:57:35
             Freeze Frame:
                    RPM: 1643 /min
                    Load: 45.9 %
                    Speed: 0.0 km/h
                    Voltage: 10.922 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:28
             Freeze Frame:
                    RPM: 1791 /min
                    Load: 30.6 %
                    Speed: 0.0 km/h
                    Voltage: 10.033 V
001393 - Brake Switch (F)
               P0571 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:29
             Freeze Frame:
                    RPM: 1099 /min
                    Load: 22.7 %
                    Speed: 0.0 km/h
                    Voltage: 11.557 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 10:20:17
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Voltage: 10.795 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI RdW 0020
   Revision: --H01---    Serial number:        0088888
   Coding: 0000001
   VCID: 2B5561898AD4A3194A-807E
6 Faults Found:
049448 - No Communications with Parking Brake Control Module
               U0128 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
             Freeze Frame:
                    RPM: 0 /min
                    RPM: 0 /min
                    RPM: 0 /min
                    (no units): 30.0
                    (no units): 145.0
                    Temperature: 22.0°C
                    T.B. Angle: 0.0°
               U0126 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
049442 - No Communication with ESP (Vehicle Dynamics) Control Module
               U0122 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
013093 - Power Supply Terminal 15
               P3325 - 000 - Implausible - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:36
006231 - Load Signal
               P1857 - 001 - Error Message from ECU - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:58:21
005889 - Transmission Control Unit
               P1701 - 000 - Locked
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:29
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
   Component: ESP 5.7 allrad  H46 0500
   Coding: 0001627
   Shop #: WSC 02313 000 00000
   VCID: 24478AB5E70A6C618B-8070
3 Faults Found:
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 -  -
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F6399878
   Coding: 0412672
   Shop #: WSC 29126 001 1048576
   VCID: 58BFEE45EBC2F881D7-800C
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
4 Faults Found:
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:57:26
02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:57:28
01332 - Door Control Module; Passenger Side (J387)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 0
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:00
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:52:24
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
2 Faults Found:
02095 - Component Protection Active
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:06
01719 - Sensor for Seat Position; Pass. Seat (G278)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2007.08.14
                    Time: 00:18:35
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 731 G    HW: 4E0 035 729 A
   Component: Interfacebox    H43 2830
   Revision: 00000000    Serial number: 300GZ067569875
   Coding: 0000002
   VCID: 254197B1EC3095699C-8070
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000015746
   Subsystem 3 - Serial number: 0118.07.060000000100010042ÿ
   Subsystem 4 - Serial number: 010042ÿ
3 Faults Found:
00384 - Optical Databus
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 25
                    Reset counter: 159
                    Time Indication: 15
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:05
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:05
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000102420
   Coding: 0057577
   Shop #: WSC 02311 785 00200
   VCID: 1C37B255DF7A54A133-8048
4 Faults Found:
01869 - Rear Left Cold / Warm Air Outlet Motor Position Sensor (G351)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:12:53
             Freeze Frame:
                    Voltage: 11.90 V
                    (no units): 187.0
                    (no units): 255.0
00819 - High Pressure Sensor (G65)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:40
01592 - Air Quality Sensor (G238)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:40
             Freeze Frame:
                    Temperature: 33.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:40
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No HW: 4E0 907 279 Q
   Component: RLS NO RESPONSE
   Coding: 0133121
   VCID: 55A1E771FCD0C5E9CC-8000
   Subsystem 1 - Part No: 4E2 910 113 B
   Component: Wischer WWS D3  H50 0420
   Coding: 00000037
   Shop #: WSC 02313
5 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:57:56
01493 - Bulb for Blinkers; Front Left (M5)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:59:00
01497 - Bulb for Blinkers; Front Right (M7)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:59:00
00908 - Control Module for Wiper Motor
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:51:05
02510 - Steering Column Adjustment
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 10:20:18
Address 11: Engine II        Labels: Redir Fail!
6 Faults Found:
               P1653 - 008 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 59
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 21:23:45
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.430 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 12
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.303 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.303 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:01
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 11.557 V
               P0513 - 008 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:29
             Freeze Frame:
                    RPM: 1112 /min
                    Load: 22.7 %
                    Speed: 0.0 km/h
                    Voltage: 11.430 V
000915 - Camshaft Position Sensor (G301)
               P0393 - 001 - Signal too High
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:50:53
             Freeze Frame:
                    RPM: 615 /min
                    Load: 27.4 %
                    Speed: 0.0 km/h
                    Voltage: 11.049 V
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H13 3710
   Revision: 91H13371    Serial number: 0037P000P8F/
   Coding: 0431707
   VCID: 275D9DB9963C8779AE-8072
   Subsystem 1 - Serial number: 63328RB401632503+
   Subsystem 2 - Serial number: 63428RB4016325332
   Subsystem 3 - Serial number: 63528RB4016324D4D
   Subsystem 4 - Serial number: 63628RB4016324E3E
   Subsystem 5 - Serial number: 63729RB4016B8A38U
   Subsystem 6 - Serial number: 63829RB4047F41D6Y
2 Faults Found:
01316 - ABS Control Module
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:05
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0112141
   VCID: 65C1D7B1ACB055695C-8030
   Component: Lenkradmodul    H07 0090
No fault code found.
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 E    HW: 4E0 920 951 E
   Component: KOMBIINSTR. VDO H82 0520
   Revision: D03         Serial number: AUDID3F6000573
   Coding: 0048413
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
             Freeze Frame:
                    Fault Status: 00000011
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:12:36
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
   Component: Gateway         H11 0090
   Revision: 11          Serial number: 20003066238076
   Coding: FCFFFBDD2B7504
7 Faults Found:
01771 - Control Module for Headlight Range (J431)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:12:36
01304 - Radio
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:13:31
01301 - Control Module for Voice Recognition (J507)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:13:31
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:12:04
00473 - Control Module for Elect. Park/Hand Brake (J540)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:12:04
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:12:04
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:46:58
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 28062006221043
   Shop #: WSC 00000 000 00000
   VCID: 1F4D8559CE6C4FB9D6-804A
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 7
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:58:56
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8161647
1 Fault Found:
02261 - Data Medium
            014 - Defective
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:00:15
             Freeze Frame:
                    Text: 00000000
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0412672
   Component: ELV                 XXXX
   XXXXXXXXXXX ELV                 XXXX
4 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:57:26
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:57:28
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 0
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:52:24
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   VCID: 2A5B648D852EBA11B1-807E
7 Faults Found:
01399 - Relay for Level-Control Compressor (J403)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 0 km
                    Time Indication: 0
00144 - Rear Left Dampening Adjustment Valve (N338)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 11101100
                    Fault Priority: 3
                    Fault Frequency: 21
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 21:24:43
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:27
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:28
01400 - Suspension Level Control
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:16:53
01769 - Sensor for Vehicle Leveling; Front Right (G289)
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:55:03
01598 - Drive Battery Voltage
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:53:03
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzmemory FS  H02  0010
   Coding: 4063330
3 Faults Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2008.01.01
                    Time: 00:00:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:06
01893 - Belt Height Adjustment Position Sensor (G372)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2008.01.01
                    Time: 00:00:00
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 D
   Component: MNS ECE         H48 0850
   Revision: 00000000    Serial number: 364G2067579658
   VCID: 3B7551C97AB43399DA-806E
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 9
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 00:59:31
             Freeze Frame:
                    Bin. Bits:     1100
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000620000052
   Coding: 0036070
   VCID: 1D31BF51C4605DA9C4-8048
3 Faults Found:
02162 - Indicator Lamp on Rear Interior Light Switch (K190)
            006 - Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100110
                    Fault Priority: 0
                    Fault Frequency: 15
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:31:00
02138 - Control Circuit for Front Right Interior Lights
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:53:00
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
   Component: Türsteuer.FS BRM003 0100
   Coding: 0032751
   VCID: 204F86A5F3127041EF-8074
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 0
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:10
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040607240256
   Coding: 0004861
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P14H06 0070
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:01
00576 - Terminal 15
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:36
01366 - Opened Due to Crash Signal
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:40
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:44:37
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:04
01699 - Motor for Central Locking; Hatch/Trunk (V53)
            014 - Defective
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 92
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2007.08.14
                    Time: 00:00:03
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 A    HW: 4E0 035 466
   Component: BO_D3           H06 0170
   Revision: 12S00002    Serial number: 00607060004114
   Coding: 0000027
   Subsystem 1 - Part No: 4E0 910 465 A
   Component: BO_D3_SLAVE     H31 0100
   Subsystem 2 - Serial number: 01407060001993
   Subsystem 3 - Serial number: 0214.07.060000000100030012ÿ
   Subsystem 4 - Serial number: 030012ÿ
4 Faults Found:
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 77
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 21:14:22
             Freeze Frame:
                    Voltage: 11.60 V
                    Temperature: 52.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 54.0°C
00474 - Unlicensed Version. Not all DTCs
            004 - will be decoded. - Intermittent
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 160
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 21:20:45
             Freeze Frame:
                    Voltage: 11.50 V
                    Temperature: 53.0°C
                    Bin. Bits: 00000011
                    Voltage: 11.50 V
                    Temperature: 58.0°C
03029 - Unlicensed Version. Not all DTCs
            011 - will be decoded.
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 79
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 21:20:45
             Freeze Frame:
                    Voltage: 11.40 V
                    Temperature: 53.0°C
                    Bin. Bits: 00000011
                    Voltage: 25.50 V
                    Temperature: -52.0°C
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 79
                    Reset counter: 119
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 21:20:45
             Freeze Frame:
                    Voltage: 11.50 V
                    Temperature: 53.0°C
                    Bin. Bits: 00000011
                    Voltage: 11.50 V
                    Temperature: 58.0°C
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000001108
   Coding: 0010101
   VCID: 1E33B85DC96646B1DD-804A
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:12:00
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:12:00
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 08:43:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 B
   Component: Türsteuer.BF BRM003 0100
   Coding: 0032751
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000731
5 Faults Found:
01315 - Transmission Control Module
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 159
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 10.77 V
                    Count: 243
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11110000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:42:20
             Freeze Frame:
                    Voltage: 11.70 V
                    Count: 15
02428 - Left Parking Brake Motor (V282) Clamping Force Not Reached
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:42:20
             Freeze Frame:
                    Voltage: 11.70 V
                    Count: 14
02427 - Brake Disk Rear Right; Not Reached
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:39:48
             Freeze Frame:
                    Voltage: 11.70 V
                    Count: 13
02426 - Brake Disk Rear Left; Not Reached
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 119
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 10.87 V
                    Count: 12
Address 55: Headlight Range
Cannot be reached
Address 56: Radio
Cannot be reached
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 A    HW: 4E0 919 148
   Component: R0078 TVhybridTuner 0280
   Revision: R0H05000    Serial number: 76300700444602
   Coding: 0000003
   VCID: 214983A1F8187949E0-8074
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000014111
   Shop #: WSC 12345 128 00289
   Subsystem 1 - Part No: JCB 4C0 626 Q2
   Component: von VA0  4F0915105E
   Coding: 4A4342344330363236513256413034463039313531303545
5 Faults Found:
02276 - Quiescent Current Stage 5
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 8
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:12:26
02274 - Quiescent Current Stage 3
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 8
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:57:46
02272 - Quiescent Current Stage 1
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 18
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:59:43
02273 - Quiescent Current Stage 2
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 02:02:53
02277 - Quiescent Current Stage 6
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 03:22:51
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0100
   Coding: 0032751
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 0
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:10
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000700046642
   Coding: 0252329
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            000 -  -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 01:11:50
             Freeze Frame:
                    (no units): 0.0
                    Temperature: 19.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 67: Voice Control
Cannot be reached
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM003 0100
   Coding: 0032751
3 Faults Found:
02127 - Exterior Door Handle Light / Mirror Light
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:06:44
02130 - Interior Door Lighting
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 0
                    Reset counter: 159
                    Mileage: 7856 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 09:47:10
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720619802191
   Coding: 0301008
   VCID: 234589A9E2046B59F2-8076
4 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:36
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:37
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 9
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:12:03
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 7858 km
                    Time Indication: 0
                    Date: 2018.07.16
                    Time: 05:20:45
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H13 0700
   Revision: 00000000    Serial number: 00000007560207
   Coding: 0010900
End-------------------------(Elapsed Time: 04:28)--------------------------
What catches my eye is the freeze frame temp is -40deg the car had no coolant in it. But I've filled it up still no start.
