Jumpy when starting off
Hi all
I have an Audi A3 2.0 diesel automatic on a 2008 plate.
The only problem I have is that when I start off from a junction or start in stop start traffic the car is very jerky once in second it's fine, it doesn't happen all the time but does seem to be getting worse, it doesn't make any difference if the cars cold or warmed up.
Any ideas gratefully received
Cheers Andy 😀👍👍
Mine is just the same, feeling as if the clutch is snatching. It only happens occasionally for me but it makes me nervous at junctions and the like. An Audi dealer I used to take it to for servicing looked a bit sheepish and said there was nothing wrong. Ha! A classic case of "the computer says no." Needless to say I don't go there any more.
Hello Andy,
I don’t know what mileage you have covered in your automatic, and indeed I’m not sure what VAG recommends in terms of transmission fluid changes (if any), but sometimes symptoms such as yours can benefit from a fluid and filter change. Not a cheap job, but the car is 11 years old, and I assume (silly me!) that it has not been done before.
If this were mine I would be entrusting an investigation to a trusted automatic gearbox specialist, and I would guess there must be some recommended business within the not too distant Midlands at least. The fluid change is often followed by resetting the correct change parameters. Perhaps someone on here could come up with a recommendation.
No doubt, whoever you chose will eliminate such possibilities as engine mountings etc.
Kind regsrfs,
