Window regulator
Hi. Does anyone have any information on how to remove the front drivers window regulator? I'm having problems with the window not going up (and a horrible noise) and think that's probably the cause.
Hi Steve Q.
Thanks very much  for the info.
With a little investigation work i sussed out how to get the panel off and access the regulator. I found out that it was one of the wires in the regulator had a bit of corrosion on it and one of the strands had snapped causing it to coil up and jam instead of sliding through the cable sleeve. Everything else looks fine so it looks like a new regulator should solve the problem.
On 6/3/2020 at 9:20 AM, Skrunkie said:
Hi Steve Q.
You're most welcome Steve, glad I could help 🙂
  • 6 months later...
Hi can I get information  on how to get the drivers window out on a 2012 a6 c7 to replace the regulator please ...Liam
Hi i have the same problem as described. I tried to open the link, it required a membership. I tried that with different emails and passwords but got errors every time. Please help if u see this. I have a new actuator have opened the trim but can't get any further.
