Would appreciate some advice on a problem I have with my 2005 B7 1.8T聽
Car has always been well serviced and recently I have an engine idle problem - runs lumpy on tickover and when I restrict on of the vacuum lines that runs under the manifold - it clears and the engine performs fine - something in the vacuum system that is causing this - I鈥檝e checked for leaks and can鈥檛 find any - the attached photo shows where I have a small vice grip restricting聽the line and the car runs 100%
any advice or recommissions would be appreciated thanks聽
Paul聽
Thanks Steve - there are so many vacuum pipes and connectors- it鈥檚 very hard to diagnose - no engine codes at all and with that pipe slightly closed off the car runs fine 馃檮
Paul聽
