High beam/climate control intermittent issues
Gwa1987
Hi I have been looking for anyone having the same issues as I have but not luck so far.
My high beam will intermittently dip at random I haven’t been able to spot a pattern for why it does this. When the high beam does dip the climate control will also cut out then come back within a second or so.
is anyone familiar with said issue?
Cheers cliff,
yeah I replaced the battery already had the charge system tested all working as it should. I know it’s an odd one but I had the typical rear washer line leak in the boot which I ended up doing a rear wiper delete and removed the pipe from the washer bottle. Dried the and cleaned up the connectors in the boot. No way this could be related??
