Broken door wires
Hi,
wiring loom has broken wires in front drivers side door so fob locking won’t work . Is there a replacement wiring harness or repair kit available?
Thank you
Got it apart today . Two chafed wires and one broken ! Should be able to solder a new wire in . The joys of it 🤣👍
Hello Andy,
Soldering good, crimping isn’t fo me.
I take it you are aware of heat shrink sleeving, which is a great way of insulation covering the joint.
Yes ,got the heat shrink . Thanks for your help guys
