Asad Posted February 12, 2022 Share Posted February 12, 2022 Hi. I have an Audi A6 C7 2012 auto s line 2.0 diesel. I had an Engine management light on recently with this message and code. P2755 transmission fluid cooler control circuit high. It goes away some times and comes back. I cleared the code with obd11 and it went away for a day but came back again. anybody can shed some light in what this could be please. is it a serious issue? The past few days I have been driving and I felt the car jerking when it switches gears around 3 to 4. it bogs down then picks up. I scanned again for codes and got the three following: throttle position sensor brake pedal released air quality sensor Am not sure if these could also affect the experience driving. other then the air quality sensor I don't know what the other two do. Please could you provide assistance. Thanks Asad Quote Link to comment Share on other sites More sharing options...
Steve Q Posted February 12, 2022 Share Posted February 12, 2022 Going from the original scan, when was the gearbox fluid last changed? If it's the dsg gearbox the gears can be affected if the oil is degrading. The throttle position sensor is more likely an issue I'd say then the others. Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted February 12, 2022 Share Posted February 12, 2022 17 hours ago, Asad said: Hi. I have an Audi A6 C7 2012 auto s line 2.0 diesel. I had an Engine management light on recently with this message and code. P2755 transmission fluid cooler control circuit high. It goes away some times and comes back. I cleared the code with obd11 and it went away for a day but came back again. anybody can shed some light in what this could be please. is it a serious issue? The past few days I have been driving and I felt the car jerking when it switches gears around 3 to 4. it bogs down then picks up. I scanned again for codes and got the three following: throttle position sensor brake pedal released air quality sensor Am not sure if these could also affect the experience driving. other then the air quality sensor I don't know what the other two do. Please could you provide assistance. Thanks Asad Hi the throttle position sensor is most likely the throttle body gunged up the other two are random and would not affect the driving of the car also look at servicing the gearbox, new filters and oil. Steve. Quote Link to comment Share on other sites More sharing options...
Asad Posted February 16, 2022 Author Share Posted February 16, 2022 (edited) Hi thanks for the reply. I will be looking to change the gear box oil. the attached picture is that a dsg gearbox? the oil that I need is it a normal cvt gear box oil? Thanks Edited February 16, 2022 by Asad . Quote Link to comment Share on other sites More sharing options...
Steve Q Posted February 16, 2022 Share Posted February 16, 2022 Not sure which oil you'll need but CVT is a different type of gearbox to dsg. Here's the oil change and oil type of a CVT: https://www.audiworld.com/forums/a6-c7-platform-discussion-194/a6c7-2015-cvt-2-0-fwd-2964451/ Quote Link to comment Share on other sites More sharing options...
