A6 bitdi Rough engine sound
Martin23
Hi
im at my wits end with this noise and no mechanic I’ve taken it too knows what it it, including Audi belfast. Noise only in D or R and at low speeds, after 4 mins warming up from cold.
I really really done want to have to change this beast
On 2/25/2022 at 11:32 PM, Martin23 said:
Hi
Hi educated guess is it might be the DMF.
22 hours ago, beemerboy9 said:
BiTDi has a torque converter gearbox with fluid flywheel.
Hi the eight speed tiptronic is as you describe but the seven speed S Tronic has two clutches and a DMF and being as he didn't  mention if the eight or seven speed box was fitted to his vehicle, like I said educated guess as most A6s around that year were fitted with the seven speed to further cut down on emissions due to faster gear shifts through the rev range.
