Asad Posted March 18 Report Share Posted March 18 Hello does anyone have an Audi A6 C7 S line 2012 wiring diagram. Having some issues with modules and it would really help. Thanks Quote Link to comment Share on other sites More sharing options...
evopilot Posted April 1 Report Share Posted April 1 there are many, any particular ones you are looking for? Quote Link to comment Share on other sites More sharing options...
Asad Posted April 1 Author Report Share Posted April 1 Hi thanks for the reply. I have the lights on for TMPS, traction control, ABS so something related to those. Quote Link to comment Share on other sites More sharing options...
evopilot Posted April 19 Report Share Posted April 19 thats a huge volume of diagrams im afraid id need something a little more specific Quote Link to comment Share on other sites More sharing options...
Magnet Posted April 19 Report Share Posted April 19 Hello Asad, ABS and Traction Control warnings are usually associated with either the ABS sensors, or the signal from the hub itself. Not sure why you are associating the issue with wiring faults before eliminating -at least - the simple sensors. Kind regards, Gareth. 1 Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted April 19 Report Share Posted April 19 47 minutes ago, Magnet said: Hello Asad, ABS and Traction Control warnings are usually associated with either the ABS sensors, or the signal from the hub itself. Not sure why you are associating the issue with wiring faults before eliminating -at least - the simple sensors. Kind regards, Gareth. Hi do you think he needs it plugged in as both the faults mentioned rear there ugly heads when the battery is failing as the main ECU goes into a default strategy to try and save the electric as both units consume a lot of power when operating. Steve 1 Quote Link to comment Share on other sites More sharing options...
