Audi TT Mk1 roadster - leaking passenger door window
Hi all,
As you can read in the title, I have a 2003 Audi TT Mk1 Roaster convertible, the passenger side door window is leaking a little when it rains. When the window is closed and all the way up, it is fully up but I can see it’s not up as tight as the other side 😞
Also, where are the drain holes for my car so I can clear them out next time it’s sunny lol
can someone help?
Thanks in advanced guys
- Wale
It's worth checking to see the window regulator is bringing the window all the way up. In failing that it sounds like the roof could have shrunk etc due to age. The roof might be able to be adjusted but it'd Ned to go to a roof specialist.
Thanks Steve. How can you check the window regulator?
