How To: Remove rear door card A6 c7
All you need is a Torx 20 bit, a flat blade or trim removal tool and some brute force!!
Top tip is to wind the window down to give you easier access when removing the door card
First you need to remove the aluminium (or whatever colour) trim by the door handle using the flat blade to reveal the two hidden screws
Back of removed trim so you can see the clips.
Then undo the screw below the door handle.
Next is to the flat blade at the bottom and start levering towards you. Once you can get your hands in simppy work your way around to the top. Don't be afraid to use a bit of brute force
Pic of the back of the door card showing the various clips
Then pull the door car up and start unclipping the plugs and door handle
Top is the speaker cable
Unclip the Yellow clip for the door handle cable
Finally undo the connector that goes into the door control module at the bottom (bottom of the pic)
Fitting is reversal of removal!! Clip the plugs and door handle cable back in
Then lift the door card back onto the lip at the top; having the window down as far is goes makes this step a little easier!
Put the screws in
Tap the clips back into place
Job done
Rhys on Audi-sport.net
