All dash warning lights coming on
On 7/18/2023 at 9:31 AM, a6blacked007 said:
Take out isofix plastics at rear push down and out then pull up front of seat clips with probably break few quid on ebay replaced mine.
Thx, yeah I did that but couldn't move the seat at all, just hear it unclipping underneath and then it wont go any further like something else is holding it in place.  I wondered if it needed some 'special' movement in certain angles to get it loose.  Seems like I just need to pull up super hard then .... so probably I am not doing it with enough strength.
  • Replies 59
  • Views 66.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • amowolves
    amowolves
    Hi Etch and all. I've just signed up as this was one of the many (prob 200+) threads I read on the internet regarding similar issues i.e TPMS, ABS, Spoiler, Park Brake, Stop Start errors etc.
  • Johnoaudia6
    Johnoaudia6
    Ah ok thanks! It happens in mine when I turn the steering wheel at low speeds ie when parking!    more recently happening all the time.. reluctant to take to Audi as they’ll charge a fortune an
  • Hey guys, my 2016 c7.5 had been suffering the same crazy ‘Christmas lights’ symptoms for more than a year. Changed 3 speed sensors, steering column (had free play anyway) yet it persisted. F
Posted Images
Could this wire be why am getting all my faults on dash not sure what it is speed sensor ??
  • 4 weeks later...
Was my passanger side front abs sensor narrowed down thanks to odis and £85
  • 3 months later...
I have this problem with my a6 2015. Is the car safe to drive?
more recently happening all the time.. reluctant to take to Audi as they’ll charge a fortune and likely just do trial and error and not sure if a kwik fit type of garage will have any idea on how to solve it…
any other suggestions from anyone I’d be most grateful for!
thanks
My 15 A6 does this too. I have done all that it says on here ie new battery, ABS sensor etc and still mine comes on as im parking or pulling out of a juntion. It always seems to be when my steering wheel is turned left for some reason. A mechanic has informed me that it must be the wiring loom for the left hand side of the vehicle and its rubbing somewhere. I dont know how this could happen but between us im sure someone can work this out. Thanks.
On 5/24/2022 at 1:07 PM, Frank Cook said:
Had similar problem in my 66 A6 Allroad - ended up new ABS unit and battery - very expensive!
Did this solve your multiple warning lights issue?
Thankyou.
  • 4 months later...
Has any one managed to get this sorted permanently, my 2012 a6 has been doing it since i bought it just under a year ago bit last night when i tried to turn the car off the hand-break wouldnt apply and the car wouldnt switch off!
I permanently sorted this bug out by changing the front wheel speed sensor harness.
