Flat battery
Hi all I have an audi a4sline cabriolet.
I have had a flat battery and my key wont work in boot. I started removing back seat to get in but I am now stuck. I cannot get the backrest off. There are only 2 seats to th rear and headrests are fixed
Any ideas pls
Phil
Hi Phil,
Sorry if this is stupid, key worked in your door?  But not in the boot, strange.  WD-40 in the lock?  Or is the mechanism seized?
Get a charger and charge the battery?  Then use the remote?
Ripping out the seats sounds a bit extreme.  Why do you need to get into the boot?
Thanks,
Joe
46 minutes ago, JMKC82 said:
Hi Phil,
Thanks,
Joe
The battery is in the boot joe
jump / charging points under the bonnet.
Thanks,
Many thanks gents I would never have guessed
Phil
